Dear Tom
I have been trying to solve this issue, physically the machine does
not have (or at least I have not found) a way to correct the
displacement of some of the axes, the bench is quite robust.
So try to solve it with geo correction table, and achieve an almost perfect circle, the deviation is 0.01mm that is fine.
But
now I have other problems, when I home the exes (x and y) the
position readout shows me a displacement of 6.604mm in both axes. (Not much problem but the operator no longer trust the machine)
When I cut a rectangle I now have a displacement of 0.1mm on one side, it's a trapezium.
Also,
we were affected to the compensation of the diameter of the tool, for
the tests we used an end mill of 20mm diameter, I usually declare it to
19.6mm because is a used tool, but after using the geo correction table I now have to
declare 18.325mm to get The final cut measure
Also the work coordinate is shifted (G55 ... G59.)
When the geo correction table is disabled, the square cut is accurate, the tool
set is the same as usual, and the working set is maintained, but the
circle cut has problems.
Unfortunately
my CAM program only reduces G2 and G3 cuts to quadrants, and the truth
is I do not know if the system is converting the arcs into segments,
because otherwise the control of the start and end points of each
segment would not allow to much deviation of the resulting arc.
Any suggestion?
this is my GEo table
2,2
28.8,28.8
-14.4, -14.4
0,0,-14.19,-14.19
0,1,14.09,14.09
1,0,-14.09,14.09
1,1,14.19,14.19
Thanks for the help
Boris B.
---In
DynoMotion@yahoogroups.com, <tk@...> wrote :
Could it be an orthogonality issue?
https://goo.gl/images/VgsCEw
Hello
I having a problems cutting circles, but first let me
explain my setup:
Kmotion+Kanalog, DC servo drive in all axes, with they
velocity control, position encoder in the Z axis screw,
and linear glass scales (heidenhain) in X and Y.
The system works fine, smooth even at high speed.
But now I need to make some very precise holes in steel,
and i was making some trials to check the the cuts,
By example a 40mm diameter hole, when i measure in the X
and Y directions a got exact measurements, but when I
check the diagonals, i got +0.1mm in one diagonal and -0.1
in the opposite diagonal.
I can pass a error of 0.03 mm maximum, but 0.1 its
too much.
So i tried to correct with the backlash but, the
error in X and Y is almost 0.01mm, in linear G1
movement. And any backlash compensation only wake worst.
Any suggestion?
